steve37066
Jun 14, 2022Tutor
RBS350 - Continuous resynching
My satellite continues to re-synch itself at irregular intervals. Firmware is V4.4.0.10. Router is RBR350 running the same version of firmware and is running in AP mode. I have tried changing the ...
KevinLiT
Jun 14, 2022NETGEAR Moderator
Hello steve37066,
I understand your RBS350 is constantly syncing and is only 15 feet away from the router. Lowering your transmit power to 50% can resolve this issue. To change your transmit power please follow the instructions below.
From the router login home page navigate to the following:
- "ADVANCED"
- "Wireless Settings"
- "Transmit Power Control"
Best,
Kevin
Community Team
- steve37066Jun 18, 2022Tutor
Hi Kevin,
Thanks for replying,
Have reduced transmit power to 50% for both 2.4 and 5GHz channels but the problem persists.
Any other ideas?
Steve
- KevinLiTJul 05, 2022NETGEAR Moderator
Hello Steve37066,
Thank you for the update!
Please check your PM.
Best,
Community Team
