CC7
Aug 08, 2021Aspirant
RBS350 Ethernet does not work
Hi, I am having issues connecting to the internet using the ethernet port on my RBS350. Is there a setting that disables ethernet ports from working?
Aug 12, 2021Guru - Experienced User
What ethernet devices are you connecting to the RBS?
Swap LAN cables as well.
Ethernet ports should be working all the time.
CC7 wrote:
Hi,
- CC7Aug 13, 2021AspirantHi latest firmware is installed and tried connecting different devices and cables. I just tried connecting to the satellites ethernet cable and that works ok. But the base router still does not any ideas
