KevinDarklight's avatar
Jun 08, 2026
RBS350 ethernet problem
I have an RBS350 satellite which disconnects from the router when I plug something into the ethernet port.
The system has an RBR350 router connected via its WAN port to the internet. There are 2 RBS350 satellites using wireless backhaul. If I plug an access point into the satellite ethernet port then that satellite disconnects from the router. It doesn't always happen straight away, but after a power failure I always need to power off the satellite and access point, then power up the satellite and then the access point in that order.
I guess it thinks that the access point ethernet is actually a wired backhaul?
Is there a way for force an RBS350 to use wireless backhaul, even if it thinks wired is available?
Kevin
  • I haven't tried any other device. It's. TP-Link TL-WR841N.
    It's been OK for a few hours today. I've just house and it never worked at the old place, possibly I've changed something.
    • CrimpOn's avatar
      CrimpOn
      The ancient WiFi access point will not cause the satellite to believe it has a 'wired' backhaul.  It is difficult to imagine why a person would want to do this in the first place.
      • KevinDarklight's avatar
        KevinDarklight
        The access point is to provide a separate 2.4Ghz network for IOT devices. Whether or not my thought on the failure mode is correct, plugging in this device makes the satellite disconnect.
  • CrimpOn's avatar
    CrimpOn
    The access point is the only Ethernet device that causes the satellite to disconnect, correct?
    What is the brand/model of this WiFi access point?
