preinvent
Dec 22, 2023Aspirant
RBS350 keeps restarting
I have a RBR750 with two RBS350 satellites. One of the satellites keeps restarting - it'll start flashing white, then a few minutes later go solid blue. Then a minute or two after that it'll start fl...
Dec 22, 2023Guru - Experienced User
What Firmware version is currently loaded on the RBR and RBS?
What is the distance between the router and 📡 satellite(s)?
Does swapping RBS around change the behavior>
- preinventDec 22, 2023Aspirant
RBR750 firmware - V7.2.6.21_5.0.20
RBS350 firmware - was V4.6.14.3, I later uploaded the version on Netgear's site which is V4.4.1.29
Home size - main house 1200sq ft with a 200 sq ft detached garage. Router is back of main house with a satellite in the garage (works perfectly) and one at the front of the house which is the one that's failing.
Distance is usually around 50 ft and it's been working perfectly for ~7 months until it started failing recently. As mentioned earlier I've tried moving to middle of the house (around 20 ft) and in the same room as the router, and the behavior is the same.
Not sure what you mean by "swapping RBS around"?
- FURRYe38Dec 22, 2023Guru - Experienced User
OK you need to downgrade the RBR back to v4 FW.
Please review all the information here:
Thanks for sharing. I'll try this. I actually upgraded to v7 when this started happening to see if that would fix it (v7 clearly states it improves stability!!) so I'm not too optimistic this will work, but I'll report back when done.
