Cfoote14
Dec 28, 2022Aspirant
RBS350 Satelites out of sync
Need help. Just installed new Orbi mesh system. Rbr 750 with two RBS350 satelites. Satelites are constantly showing out of sync for backhaul status. However connection is good and anything hardwired i...
- Dec 28, 2022
OK yes, the RBS are behind. Can you access there web pages with a PC and web browswer by navigating to there IP addresses seen on the RBRs web page? If so, manually update the RBS:
Cfoote14
Each satellite shows firmware 4.6.3.16 when I login to their website but does not show a firmware number in the Orbi app. Everything I’ve read seems like it’s a firmware issue. Do I need to update?
Dec 28, 2022Guru - Experienced User
What FW version is on the RBR750?
Is this system from the RBK650 series kit box?
