Cfoote14
Dec 28, 2022Aspirant
RBS350 Satelites out of sync
Need help. Just installed new Orbi mesh system. Rbr 750 with two RBS350 satelites. Satelites are constantly showing out of sync for backhaul status. However connection is good and anything hardwired i...
- Dec 28, 2022
OK yes, the RBS are behind. Can you access there web pages with a PC and web browswer by navigating to there IP addresses seen on the RBRs web page? If so, manually update the RBS:
Cfoote14
System is from RBK653-100NAS
FW on RBR750 is V4.6.14.3
Dec 28, 2022Guru - Experienced User
