Retired_Member
May 01, 2023RBS350 satellite connectivity issues
Hi Netgear community, i have an RBR350 and 2x RBS350 satellites (WiFi6 dual band mesh system). I installed the satellites in the roof cavity of my home at the furthest points of the roof and have...
May 01, 2023Guru - Experienced User
So its only devices in the detached building that are having issues?
My bet would be on the exterior walls of both. Exterior walls tend to be made with materials that do a great job of blocking wifi. LIke cement board, brick, adobe, foil lined insulation, metal siding,etc.
If its only the devices in the detached having issues, I'd be betting on that being the problem.
