Therugbyref
Jul 26, 2021Follower
RBS350 Satellite constantly synchronising
I have two RBS350 satellites which are daisy chained. The furthest stallite in the chain, which shows green on the network map is constantly flashing white which I believe means it is synchronising ...
Jul 27, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
