Therugbyref
Jul 26, 2021Follower
RBS350 Satellite constantly synchronising
I have two RBS350 satellites which are daisy chained. The furthest stallite in the chain, which shows green on the network map is constantly flashing white which I believe means it is synchronising ...
Jul 28, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Therugbyref wrote:I have two RBS350 satellites which are daisy chained. The furthest stallite in the chain, which shows green on the network map is constantly flashing white which I believe means it is synchronising with the RBR350 router. Is this normal?
