Rob6805
Nov 21, 2022Tutor
RBS350 satellites lose sync with RBR750
Hello all, I am having issues with my brand new Orbi system. I have a RBS750 router and two RBS350 satellites. The satellites will not maintain a good backhaul sync status. I have tried resett...
CrimpOn
Nov 21, 2022Guru - Experienced User
Page 133 of the user manual. The satellites use channel 157 for both user WiFi and backhaul. The router uses different channels for each. (48 user, 157 backhaul)
Still no
Rob6805
Nov 21, 2022Tutor
That is not good. I thought the satellites mirrored the router. I do not believe the camera supports ch 157. Do you know if this can be changed?
Thank you,
Thank you,
