Rob6805
Nov 20, 2022Tutor
RBS350 satellites lose sync with RBR750
Hello all, I am having issues with my brand new Orbi system. I have a RBS750 router and two RBS350 satellites. The satellites will not maintain a good backhaul sync status. I have tried resett...
Hammerlee
May 20, 2023Star
That is the impression I am getting too after dealing with the Gear Head staff. Going to try new HW since I was still under warranty...but don't have high hopes.
Rob6805
May 20, 2023Tutor
Hi
Yes, exactly. I also talked to their tech support multiple times. They had no answers as to why the satellites would not stay in sync. They had me try multiple resets and re-sync procedures and each time the satellites would stay in sync for a few minutes and then proceed to go out of sync. They had zero answers. Sorry to say that Netgear has an issue with their Orbi system that they don't know how to resolve.
- HammerleeMay 21, 2023StarI am beginning to think I am going to turn off auto firmware upgrades and manually do satellites first then the router. After reading through other threads there seem to be issues with firmware upgrade introducing issues when satellites get out of version. Sad it might take that much maintenance for a home router .but worth a try. BTW, one of the crack support staff did mention that there is a known issue with this mesh system and cameras. Thought it had something to do with the 5GHz signal but might work better limiting to 2.4GHz. Never could get anyone to repeat that and camera connections were the least of my worries with this system.
- HammerleeJun 02, 2023StarUpdate: got the replacement hardware and low and behold...the Satellites looked and were sized the same and looked just like the router, had a model # rbs750 which makes sense since I purchased an rbr750, and most importantly, it works. Devices are being picked up by the satellites the way they should and set up was a lot more straight forward. The original box I received had the wrong hardware...so not only is their service awful but quality control is ridiculous too. Maybe they are the same people???
- Rob6805Jun 02, 2023TutorHey. How did you get replacements? I always thought it was strange that the RBR750 router was paired with RBS350 satellites in the kit that I got.
- HammerleeJun 02, 2023StarThe hardware is warrantied for a year. Just had to sit through a day of troubleshooting to prove it was hardware. This IS your problem... My case is proof.
