tawiii
Nov 19, 2023Follower
RBS350 satellites losing connection to RBR750
I have been using this system for almost a year now and recently have started encountering issues with the satellites connecting and disconnecting with the router. The satellites show up under attac...
Nov 19, 2023Guru - Experienced User
You'll need to downgrade the RBR back to v4 FW.
FYI:
Please review the NOTES from this link.
tawiii wrote:
I have been using this system for almost a year now and recently have started encountering issues with the satellites connecting and disconnecting with the router. The satellites show up under attached devices as disconnected. The light on the satellites will show blue for about 3-5 minutes and then start flashing white again as if they are attempting to reconnect.
I have deleted the satellites from the device list and re-synced, as well as done a factory reset.
I have checked the firmware for the RBR750 and it appears to be up-to-date 7.2.6.21. The satellites will not stay connected long enough for me to find out what version firmware they have. I have read on one post that an older firmware might need to be used and in another that using older firmware is not recommended.
At one point I had the satellites within 10 feet of the router so distance is not an issue.
Looking for suggestions.
