Jcabrera108
Sep 14, 2022Tutor
RBS350 Satellites won’t connect devices
I recently purchase an Orbi mesh wifi system with an RBR750 router and 2 RBS350 satellites. I set up the system and and I’ve noticed that all my devices are connecting directly to the primary router, ...
- Sep 16, 2022So I was to resolve the issue by log in directly to the satellites by entering in their generated IP address. Through their I could see the devices currently attached to each satellite. I was not able to do this through the app, as I had with my TP-Link Deco app previously. It’s pretty disappointing that such a well known networking company like Netgear has such a bad app. But it is what it is. Thanks to everyone who made suggestions.
Jcabrera108
Sep 16, 2022Tutor
ekhalil take a look at this recen screenshot. It does not show any connected devices.
ekhalil
Sep 16, 2022Master
What is the firmware on the satellites? If you have the latest then you should see a picture of the RBS350. What you attached shows a picture of RBS50. I think I had it this way few releases back.
Please make sure to upgrade the satellites to 4.6.9.11
- Jcabrera108Sep 16, 2022Tutorekhalil, my main router is running V4.6.9.11, I don’t see the firmware listed for the satellites. You can see the attached picture to see for yourself. When I get home I will sign in to each and find out.
- Jcabrera108Sep 16, 2022Tutorekhalil I was able to update the firmware of the satellites to latest 4.6.9.11 version. I had to manually download the firmware and upload it through the website (the satellite’s IP address). That fixed the issue and I can now see the connected devices via the app. Thanks for all of your help. Much appreciated.
- ekhalilSep 16, 2022Master
Glad that you got the issue solved now with the latest firmware.
