bryantlikes
Oct 25, 2021Aspirant
RBS40V with RBR850
Hello, I just upgraded from an RBR50 Orbi Mesh to the new RBR850 Orbi mesh. As part of my upgrade process I created a new SSID and used the old SSID as the guest network since I wanted all my non-es...
Oct 25, 2021Guru - Experienced User
An the RBS40 isn't getting any correct sync information from the RBR?
Does the RBR web page show the RBS40v connected or disconnected? Show out of sync?
I think there is one other user that posted that his RBS50 that were wired were not connecting right since v4 FW was updated...
- bryantlikesOct 25, 2021Aspirant
Did you read my post FURRYe38 ? I'm connected using wired.
