CR-sound
Jan 16, 2022Aspirant
RBS50 connection to network without internet
I have a 6 year old RBR50 Orbi mesh system with 2 RBS50s, an RBW 30, and an RBS50y (outdoor). The RBS 50 & RBW30 units need to be rebooted often to provide wireless internet access , Devices such as a Galaxy 21Ultra will show network connected with no internet. The problem involves both 2.4G and 5G wireless connections. Rebooting solves the problem temporarily. Walking from the area covered by a satellites to the area covered by the main router solves the connectivity.
Router firmware for the RBR50: V2.7.3.22, for the RBW30: 2.6.2.6, for the RBS50: 2.7.3.22.
Wondering if I have a router going bad or what?
If I do need to replace the router, will my current satellites work with a new version of Orbi? I particularly am concerned about the outdoor RBS50Y.
Appreciate the help!
- KevinLiTNETGEAR Moderator
Hello CR-sound,
I understand your Galaxy 21Ultra connects to the RBS50 and the RBW30 wireless connection but does not get any internet from the service provider.
Please try moving the RBS50 closer to the router and observe the connection status.
Please let us know the results to this solution!
Best,
Kevin
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
- CR-soundAspirant
Distances are over 30 feet. Need to mention that in the six years since purchase, there has been no problem until recently. Home is around 3,000sqft.
Any advise on whether new er Orbi systems support the outdoor satellite?
Thanks!
That size of home, the RBR and just 1 RBS would only be needed, then maybe the RBSY outside at a distance from nearest RBR or RBS for it to connect too. Yes Orbi AC supports RBSY outdoors.
