ssgtweasel
Jan 26, 2021Guide
RBS50 wired to RBR850 is connected but no devices registered via wifi?
I just purchased the RBK850 (router and satellite) to replace my current RBR50 with 2 RBS50s RBR850=Firmware Version: V3.2.17.12_1.4.14 RBS850=Firmware Version: V3.2.17.12_1.4.14 I have an exis...
ssgtweasel
Jan 27, 2021Guide
A laptop with cat6 is connected to the RBS50 that is connected to my core 1gb switch
So the data switch portion of the RBS50 is working
No devices are connected wireless to the RBS50
Will disable my RBS850 satellite to see if the wireless devices that used to connect to the RBS50 will do so again
Jan 27, 2021Guru - Experienced User
"RBS50 that is connected to my core 1gb switch"
What is the mfr and model of this switch?
- lfw2068Feb 14, 2021Aspirant
Hello, I have the same problem. Were you able to figure out how to get WI-FI devices connected to the RBS50 wired as a satellite to the RBR850?
- FURRYe38Feb 14, 2021Guru - Experienced User
So your wired RBS50 connected to the RBR850 doesn't accept any wireless connections with devices or devices will not connect to the RBS50?
lfw2068 wrote:Hello, I have the same problem. Were you able to figure out how to get WI-FI devices connected to the RBS50 wired as a satellite to the RBR850?
The 850 is connected to a 1gb netgear switch to which the RBS50 is wired to. The 50 shows as a satellite but shows no wireless device connected to.
how do I check the firmware version? It does not show in the app when I select details?
