liquid1287
Mar 08, 2022Tutor
RBS50 won't connect to RBR850 wirelessly and keeps broadcasting default SSID
Sigh... I have an RBR850 and RBS850 connected via backhaul working fine. My problem lies when trying to add an RBS50. If connected via backhaul it shows connected but no wireless devices connect. O...
- Mar 08, 2022
RBS50 series are not compatible nor supported on Orbi AX series systems.
liquid1287
Mar 08, 2022Tutor
Well Fu**
Mar 08, 2022Guru - Experienced User
Ya, used to be that RBS50 connected via etherent worked however NG seemed to have closed the door on that one as well.
There a need for additional wifi coverage with your current system?
- liquid1287Mar 08, 2022Tutor
Yes, due to my house setup one more access point would be helpful.
- FURRYe38Mar 08, 2022Guru - Experienced User
What is the distance between the router and 📡 satellite(s)?- liquid1287Mar 08, 2022Tutor
2400sq ft ranch with full basement. Router is in basement corner. Satelite is on main level about 65ft away.
