tempest68
Feb 17, 2022Aspirant
RBS750 - firmware suggests a roll back
I have a RBR750 router and (2) RBS750 satellites. I am running FW 4.6.5.14. I have one RBS750 satellite suggesting to rollback to FW 4.6.3.16. What do you suggest to ensure all run the same FW versi...
tempest68
I have not performed a power off with the router. I can do that then reconnect the saltellites one by one. The satellites are wireless to the router adn they are aproximately 60 ft away. They have worked flaswlessly for the past 2 years. I started to get some random drops and noticed that one satellite was at a different FW version. So I manually updated and not it says it wants an older version. So odd.
Feb 17, 2022Guru - Experienced User
Let us know what happens after you power everything OFF for 1 minute or longer.
