rob_mcintosh
May 23, 2022Tutor
RBS750 - Satellite "Connected" But Not Showing Up
Found that 2 of my 3 satellites were not connected. I tried to sync continuously with no avail. I eventually reset the entire system at the router and each of the satellites. 2 still fail to conne...
May 24, 2022Guru - Experienced User
Is your RBS connected to a CBR750?
rob_mcintosh
May 24, 2022Tutor
No - it is connected to an RBR750
- FURRYe38May 24, 2022Guru - Experienced User
Have a screen capture if what this looks like?
Is this in the RBR web page or Orbi app?
- rob_mcintoshMay 24, 2022Tutor
Be it the orbilogin or the app, the 2 satellites do not show up in the map of either connected devices nor connected satellites.
What happens if you bring one RBS to the same room as the RBR and ethernet connect it to the back of the RBR?
