rob_mcintosh
May 23, 2022Tutor
RBS750 - Satellite "Connected" But Not Showing Up
Found that 2 of my 3 satellites were not connected. I tried to sync continuously with no avail. I eventually reset the entire system at the router and each of the satellites. 2 still fail to conne...
rob_mcintosh
May 24, 2022Tutor
No - it is connected to an RBR750
May 24, 2022Guru - Experienced User
Have a screen capture if what this looks like?
Is this in the RBR web page or Orbi app?
- rob_mcintoshMay 24, 2022Tutor
Be it the orbilogin or the app, the 2 satellites do not show up in the map of either connected devices nor connected satellites.
- FURRYe38May 24, 2022Guru - Experienced User
What happens if you bring one RBS to the same room as the RBR and ethernet connect it to the back of the RBR?
Hmm. Ok - connecting it to the RBR created a short sign of life. It now shows up as a satellite, but says it is Disconnected. I powered it down and tried to sync process again and cannot get it to sync. The Satellite is within 10' of the RBR.
- KevinLiTMay 24, 2022NETGEAR Moderator
Hi rob_mcintosh,
Please check your PM so I can further assist you on this issue!
Best,
Kevin
Community Team
