RichSNJ
Feb 14, 2021Aspirant
RBS750 - Satellite connected via Ethernet and works, but isn't displayed by Router
Hi, I'm new to Orbi, but my colleague has used it several times. We have a client with an old stone house and had tried several different solutions, but he had horrible wifi. We decided to try t...
RichSNJ
Feb 15, 2021Aspirant
PS, I figured since I was in there I would go ahead and manually update the fw on that one to match the other two, so I just did that successfully and it rebooted. So I guess if I want to reboot a satellite I can always reload the firmware :)
Feb 15, 2021Guru - Experienced User
RBR and all RBS should be on same version of FW.
- RichSNJFeb 15, 2021Aspirant
Unfortunately the recommended fw update procedure is performed through the router for the connected satellites, and since it didn't see it, it wasn't able to do it. But as I said this morning, I did go and manually update the missing satellite and they are all now the same version.
