JasGr81
Mar 05, 2025Aspirant
RBS750 & RBR750
I updated my RBR750 router and the RBS750 Satellites a few days ago however one Satellite I have is showing as disconnected on the web UI. I have reset it and removed it from the Attached Devices page...
Mar 05, 2025Guru - Experienced User
Did you update the RBS first using it's web page then the RBR lastly?
Does the RBS appear in the RBRs web page under administration/FW update and checking for new version of FW?
How about factory reset the RBR as well?
I'd follow this PDF process:
