JasGr81
Mar 05, 2025Aspirant
RBS750 & RBR750
I updated my RBR750 router and the RBS750 Satellites a few days ago however one Satellite I have is showing as disconnected on the web UI. I have reset it and removed it from the Attached Devices page...
JasGr81
Man I honestly don’t even know if I updated it first. I’ll be home again shortly and I’ll let you know more. If I factory reset the RBR I’ll have to manually reconnect all my devices won’t I?
- FURRYe38Mar 05, 2025Guru - Experienced User
If you use same SSID name and PW, devices will re-connect on there own.
Possible the RBS FW level if not updated first before the RBR is, could cause this...
- JasGr81Mar 05, 2025AspirantSo the update page is showing the Router with V7.2.6.31 Firmware then it shows three of my RBS Satellites have V7.2.7.15 Firmware. Then the other RBS isn’t even showing up on the update page. Also one of the satellites says Update Failed. But that Satellite is showing up on the Firmware update page.
Ok I see one of the RBS750s is showing RBS750QV. Something another poster contacted me about.
This needs to get over to NG since we are seeing two systems that exhibit this issue.
- JasGr81Mar 05, 2025AspirantDid you get the photo I sent?
How was the system updated?
Did you use the UPDATE ALL button or did you manually update the RBS first then RBR lasly using there web pages to send the FW update files with a web browser?Someting in the updating process is messing up the RBS750 during the FW update process or end result. Not sure what is causing this. This is a first.
