JasGr81
Mar 05, 2025Aspirant
RBS750 & RBR750
I updated my RBR750 router and the RBS750 Satellites a few days ago however one Satellite I have is showing as disconnected on the web UI. I have reset it and removed it from the Attached Devices page...
Mar 05, 2025Guru - Experienced User
If you use same SSID name and PW, devices will re-connect on there own.
Possible the RBS FW level if not updated first before the RBR is, could cause this...
JasGr81
So the update page is showing the Router with V7.2.6.31 Firmware then it shows three of my RBS Satellites have V7.2.7.15 Firmware. Then the other RBS isn’t even showing up on the update page. Also one of the satellites says Update Failed. But that Satellite is showing up on the Firmware update page.
- FURRYe38Mar 05, 2025Guru - Experienced User
Ok I see one of the RBS750s is showing RBS750QV. Something another poster contacted me about.
This needs to get over to NG since we are seeing two systems that exhibit this issue.
JasGr81 wrote:
So the update page is showing the Router with V7.2.6.31 Firmware then it shows three of my RBS Satellites have V7.2.7.15 Firmware. Then the other RBS isn’t even showing up on the update page. Also one of the satellites says Update Failed. But that Satellite is showing up on the Firmware update page.- JasGr81Mar 05, 2025AspirantWhat does that mean?
- BlackdogaudioMar 05, 2025Guide
Just linking myself to this conversation. I'm the other poster Furry has been working with today after FW. 7.2.7.15 fails to install on my RBS750 and yet changes the Model Name to RBS750QV in the web interface in my photo above.
I've made NG aware of this.
I guess for now, use the system with prior working version of FW. Blackdogaudio
For the one RBS that didn't seem to update, can you use the system with out that RBS is is that needed?
May need to possiblty downgrade the system back to prior working version of FW.
I'll see what NG needs from you both, debug logs maybe needed. Please be patient.
