JasGr81
Mar 05, 2025Aspirant
RBS750 & RBR750
I updated my RBR750 router and the RBS750 Satellites a few days ago however one Satellite I have is showing as disconnected on the web UI. I have reset it and removed it from the Attached Devices page...
JasGr81
Okay will do. Sorry for the late reply I was busy with something. So the Satellite with QV at the end what is that exactly?
Mar 05, 2025Guru - Experienced User
No idea. This is all new and never been seen before. I don't believe that should be there.
- JasGr81Mar 05, 2025AspirantYea everything was working perfect until I did the update and now instead of having 4 RBS750 Satellites and one RBR750 Router I have 2 RBS750QV Satellites and 2 RBS750 Satellites? Little weird!
- FURRYe38Mar 06, 2025Guru - Experienced User
Well, could do this, if you do need the RBS to work correctly, Can use the RBS web pages to downgrade back to last working version of FW or v.21 which is most stable, after all RBS are downgrade, down grade the RBR using it's web page lastly. After the system is back to ready, you'll need to factory reset the system and setup from scratch. I found this PDF process to work the best:
NG will need to take a look into this and find out what's going on with this being seen on the RBR and RBS when FW is updated to the system.
JasGr81 wrote:
Yea everything was working perfect until I did the update and now instead of having 4 RBS750 Satellites and one RBR750 Router I have 2 RBS750QV Satellites and 2 RBS750 Satellites? Little weird! - FURRYe38Mar 06, 2025Guru - Experienced User
Can you still access the RBS web page when the QV was present after the FW updated on the RBS?
