SteveRNolan
Jan 10, 2023Aspirant
RBS750 and long range reception
Hello all, I have my house all set up with the RBS750 WiFi 6 system with 3 satellites. I have a shed 400 feet away that I want to have on the wifi network so I can remote connect to the computer out...
SteveRNolan
Yeah no way to use CAT cable for hardwire, needs to be wireless. The antenna is connected to CCRane's Vector router that rebroadcasts the signal it receives from the house wifi, and the rebroadcast is a different network (SSID).
Jan 10, 2023Guru - Experienced User
Ah...ok. So there is another router there. You might see if there is a DMZ or IP pass thru option on there router that you could put your PC in and see if this helps get the remote desktop connection working thru there router to the Orbi system.
