sethm1
Mar 24, 2022Guide
RBS750 and most nites
Attempted the update to 4.6.7.13. The firmware update screen on my windows 10 PC - in my home's Orbi website was only able to show the new firmware for the router & one of my satellites. The other ...
Mar 25, 2022Guru - Experienced User
Just follow the manual update procedures by updating using the RBS and RBRs web pages and update by downloading the FW file to the RBS first, the RBR lastly.
sethm1
Mar 25, 2022Guide
Question - is it possible that a firmware updated not available for one of my satellites?
last nite I was using our downstairs pc and where the router is wired into.
Just now turned on my upstairs pc and which is closest to satellite 2. This Sat about 20 feet from this pc. Went to the router login page and then to the firmware update page. For Satellite 2 it says ‘no firmware available.’ As noted above, router & Sat 1 now have 4.6.7.13 so obviously
‘no firmware available‘ - so thats correct.
what is odd on the firmware update page/screen - the model name & current firmware version is not showing up.
yes, the 2 satellites came with router.
- FURRYe38Mar 25, 2022Guru - Experienced User
sethm1 wrote:
Question - is it possible that a firmware updated not available for one of my satellites? No. Thought I don't trust the auto updater to properly handle FW udpates on Orbi systems. So I always manually update the RBS first then RBR lastly.
