bevvobevvy
May 17, 2022Guide
RBS750 boot-loop... just blinks white.
Hi All RE: RBK752 My 750 Satellite has gone into what appears to be a boot loop. My main router is fine. The RBS stopped connectivity to my TV/Cable boxes 3 days ago. - i have power cycle...
- May 31, 2022
a firmware fix for the RBS issue >
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/RBK750-and-850-Series-Firmware-Version-v4-6-8-2-Available/td-p/2228203/jump-to/first-unread-message
FURRYe38 thanks
May 18, 2022Guru - Experienced User
What happens if you connect the RBS to the back of the RBR using a ethernet cable?
Does the RBS appear with a IP address on the RBRs web page under Connected Devices?
bevvobevvy
May 31, 2022Guide
FURRYe38 thanks so much 👍... I have read your recent post >>>
This explains a big part of my problem. I'll reload firmware and get back up and running.
I appreciate the sometimes thankless work you do for the Orbi community.
Bestwishes
bevvybevvy
