Foutiti67
Apr 07, 2022Aspirant
RBS750 connect with Wired connection
Hello everyone, I recently moved my satellite and I have connect this with ethernet (because it is too far from the router). All work fine ( good connection) but when I see in orbi app or orbi rou...
- Apr 07, 2022
Switch may not be fully compatible with Orbi systems. "Green Ethernet" features seen on some switches can cause odd problems.
Something to try if you can, remove the switch and connect the RBS or one RBS directly to the back of the RBR and see if this changes the behavior seen.
Also be sure your using good quality LAN cables. CAT6 is recommended.
Also you should be using channels 1, 6, 11 or 13 on 2.4Ghz. Not channel 4.
Foutiti67 wrote:
The switch is a DLINK DGS-1008P ( I don't know what is MFR )
Apr 07, 2022Guru - Experienced User
Please provide a screen capture of what you see on the Orbi app and RBRs web page.
What browser are you using when connected to the RBRs web page? Same thing happen in different browsers?
How is the RBS connected to the RBR, directly behind the RBR or is there a LAN switch in between?
Foutiti67
Thank you for your help .
The firmware is the last one ( 4.6.7.13 on rbr and rbs)
My provider is a French operator ( orange ) I have a fiber box and rbr is connect on this ( ap mode )
I will send to you some screenshot when I will at home .
The satellite is connected not directly ( lan switch between the two )
