Foutiti67
Apr 07, 2022Aspirant
RBS750 connect with Wired connection
Hello everyone, I recently moved my satellite and I have connect this with ethernet (because it is too far from the router). All work fine ( good connection) but when I see in orbi app or orbi rou...
- Apr 07, 2022
Switch may not be fully compatible with Orbi systems. "Green Ethernet" features seen on some switches can cause odd problems.
Something to try if you can, remove the switch and connect the RBS or one RBS directly to the back of the RBR and see if this changes the behavior seen.
Also be sure your using good quality LAN cables. CAT6 is recommended.
Also you should be using channels 1, 6, 11 or 13 on 2.4Ghz. Not channel 4.
Foutiti67 wrote:
The switch is a DLINK DGS-1008P ( I don't know what is MFR )
Foutiti67
Thank you for your help .
The firmware is the last one ( 4.6.7.13 on rbr and rbs)
My provider is a French operator ( orange ) I have a fiber box and rbr is connect on this ( ap mode )
I will send to you some screenshot when I will at home .
The satellite is connected not directly ( lan switch between the two )
Apr 07, 2022Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
- Foutiti67Apr 07, 2022Aspirant
- CrimpOnApr 07, 2022Guru - Experienced User
MFR is shorthand for Manufacturer. Is this the switch:
- Foutiti67Apr 07, 2022AspirantYes it is .
- FURRYe38Apr 07, 2022Guru - Experienced User
- Foutiti67Apr 08, 2022AspirantOk i will try this tonight . Thanks you
If it don’t work , a reset can resolve it ?
