Foutiti67's avatar
Foutiti67
RBS750 connect with Wired connection
Hello everyone,  I recently moved my satellite and I have connect this with ethernet (because it is too far from the router). All work fine ( good connection) but when I see in orbi app or orbi rou...
  • FURRYe38's avatar
    Switch may not be fully compatible with Orbi systems. "Green Ethernet" features seen on some switches can cause odd problems.
    Something to try if you can, remove the switch and connect the RBS or one RBS directly to the back of the RBR and see if this changes the behavior seen.
    Also be sure your using good quality LAN cables. CAT6 is recommended.
    Also you should be using channels 1, 6, 11 or 13 on 2.4Ghz. Not channel 4.
    Foutiti67 wrote:
    The switch is a DLINK DGS-1008P ( I don't know what is MFR )
