skous
Jun 19, 2023Aspirant
RBS750 Daisy-Chain Slow Speed
Hello there I have a 300Mbps fiber and I have the following Setup RBS750 (Main Router) -> RBS750 (1st Satellite) -> RBS750 (2nd Satellite (daisy-chained to 1st Stellite). The Backhaul Sta...
- Jun 21, 2023
You still loose speed with distance over 5ghz. It doesn't broadcast as far or through as much materials as 2.4ghz but is significantly faster.
but you're still starting at 300mbps so its drop off starts there.
Jun 21, 2023Guru - Experienced User
A wired backhaul would be about it.
You're going to lose speeds with a daisy chained setup.
it also implies that you have a decent amount of distance between the devices which causes losses because of the distance/interference.
- skousJun 21, 2023Aspirant
Wired would not be a possiblity.
The daisy-chained satellites are more or less 10meters far. So I think distance is ok.
- plemansJun 21, 2023Guru - Experienced User
- skousJun 22, 2023Aspirant
Ok understood.
Problem is my office resided at the final satellite 🙂 But I can leave with 200Mpbs for now
