skous
Jun 19, 2023Aspirant
RBS750 Daisy-Chain Slow Speed
Hello there I have a 300Mbps fiber and I have the following Setup RBS750 (Main Router) -> RBS750 (1st Satellite) -> RBS750 (2nd Satellite (daisy-chained to 1st Stellite). The Backhaul Sta...
- Jun 21, 2023
You still loose speed with distance over 5ghz. It doesn't broadcast as far or through as much materials as 2.4ghz but is significantly faster.
but you're still starting at 300mbps so its drop off starts there.
skous
Jun 21, 2023Aspirant
Wired would not be a possiblity.
The daisy-chained satellites are more or less 10meters far. So I think distance is ok.
Jun 21, 2023Guru - Experienced User
- skousJun 22, 2023Aspirant
Ok understood.
Problem is my office resided at the final satellite 🙂 But I can leave with 200Mpbs for now
