hd1106
Sep 11, 2022Aspirant
RBS750 Doesn't act as a satellite anymore
Hello, my satellite doesn't act as a satellite/extender anymore. No devices can connect to it wireless but the ethernet ports work just fine. I've tried resetting both the router (CBR750) and the sat...
- Sep 11, 2022
You need to downgrade the RBS FW to what is posted here for the CBK7 series system:
https://www.netgear.com/support/product/cbk752.aspx#download
Do not use RBK7 series FW for RBS that come with the CBR750!
Sep 11, 2022Guru - Experienced User
- hd1106Sep 11, 2022Aspirant
OMFG that fixed it. Thank you sir. I was so confused and spent hours researching.
- FURRYe38Sep 11, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
