FoReVeRJsUs
Apr 15, 2022Aspirant
RBS750 ethernet port not working
Everything is working but when I tried to connect anything on the satellite using Ethernet port
Apr 15, 2022Guru - Experienced User
Power OFF and back ON?
Using good quality LAN cables? CAT6 is recommended.
MIght contact NG support to see what your options are if nothing helps...
- FoReVeRJsUsApr 15, 2022AspirantHi,
I have Already tried that. Same result- FURRYe38Apr 15, 2022Guru - Experienced User
Press the reset button for 15 seconds then release then resync. Check the LAN ports.
Sounds like a HW failure on the RBS...
- FoReVeRJsUsApr 15, 2022AspirantI have tried that as well. What is weird is that the lights are on for while and then after they turn off. No IP address assigned or device connected on the network
