Therapydoc's avatar
Therapydoc
Rbs750 Ethernet setup
I have an Rbr750 set up as my main router inside the house as well as one RBS 7:50 in the basement and as far as the house I get pretty good coverage. What I’m looking to expand is the outside pool area/pool house and my shop. Both of those areas have a cat 5E cable to get Ethernet connection. The trouble I’m running into is that I cannot get the satellites to stay connected even though they are a wired Ethernet connection. The main wire does run down stairs into a tp link switch box and from there I have about 6 wired connections I use. One to poolhouse (75 feet from house) one to shop (250’ from house) and remaining go to devices in the home. These are all hardwired so I cannot change to cat 6 (regrettable at this point). I did try to use rbs40v x 2 as extenders but I had tons of trouble with signal using them and tried to use them in the house and out in the poolhouse to no avail so I’ve gotten rid of those and just have main router and two satellites now. Ideally I’d like to add one more satellite
My question is, is there a setting I need to change in my advanced settings for the main router or anything to get my signal to stay on via Ethernet cable ?
  • FURRYe38's avatar
    What model # is the switch?
    Be aware that some LAN switches, managed or with green ethernet can cause problems with Orbi systems and ethernet connected RBS. Non managed switches and non manage switches with out Green Ethernet features are recommended.
    NG GS-105/108v4 and GS308v3, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
    Also CAT6A STP (sheilded twisted pair) lan cabling is recommended of long distance or outside cable run installations.
    • Therapydoc's avatar
      Therapydoc
      The switch is tp link tl-sg108 and it does have the little green lights on each port. I’ll try to get one of those other switch boxes.
      As far as wiring I can’t change it at this point. It’s in conduit but is also Pulled with multiple other wires.
      • FURRYe38's avatar
        Ya this switch as some green ethernet so maybe one cause of problems:
        https://www.tp-link.com/us/business-networking/unmanaged-switch/tl-sg108/
        Try a different brand switch and to test this, try the RBS with the new switch in the same room or near by the RBR and run out of wall patch cables as a temp test to see how the RBS connects and syncs. Should work here. Then power OFF and put the RBS back in remote location using in wall cabling. IF the RBS has issue after this, then you'll need to investigate the in wall cabling and connectors and jacks.
  • CrimpOn's avatar
    CrimpOn
     Although the RBS40V has limited compatibility with the RBR750 router (i.e. only in Extender mode), it is not clear (to me) that Extender mode functions using an Ethernet connection.
    https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
    The only satellites which will function as a satellite with the RBR750 router are the RBS750, RBS840, and RBS850.
    I would expect all of those to work over a wired backhaul.  (Not so confident about the RBS350.)
    Although not the most capable medium, Cat5E cable will support gigabit up to 90 meters, which is more than the distance to the shop.
    If you want to roam seamlessly between units, only the truly compatible satellites (see above) will function in that mode. For the shop that is 250' away, there is a good chance that mobile devices may totally lose connection somewhere in between and simply connect to WiFi when the signal is strong enough.  Thus, any WiFi access point which is designed to connect to the host router over Ethernet may be sufficient.  (WiFi routers can often be placed into Access Point (AP) mode and function the same way.)  WiFi access points are available on Amazon for under $50.
      Therapydoc
      I’ll have to look into the wifi access points. So you’re saying any brand of those will work via wired connection ? Are there any certain ones your recommend ? When I was using my my ISP equipment, they had a router or AP in the shop and it worked great. The problem with their equipment was that I was not getting great house coverage and they wanted me to add 3 more satellites to get coverage at $10 each per month so made no sense not to buy my own system.
      • CrimpOn's avatar
        CrimpOn
        TP-Link TL-WA1201 sells for $40 on Amazon. It has only one gigabit Ethernet port for user devices.  If you need more 'wired' devices in the shop that implies adding an inexpensive switch or moving up to a product with more ports, such as the Archer AX55. ($108)
