jonseff
Oct 07, 2021Tutor
RBS750 firmware update issues
My old Orbi system died and I replaced it with a RBR750 + 2 RBS750 satellites. Had lots of trouble updating firmware and now that I've added a third satellite I'm having the same problems. When I log...
jonseff
Oct 07, 2021Tutor
How do I get the IP address for the individual satellites?
Oct 07, 2021Guru - Experienced User
Look at the RBRs web page under Conencted devices. IP address will be seen for each RBS here.
- jonseffOct 07, 2021Tutor
Thanks, was able to update firmware that way! Also noticed that satellite 2 is listed as "Out of Sync."
- FURRYe38Oct 07, 2021Guru - Experienced User
Ensure all are on same version of FW. Once updated. Power them OFF, then power ON on at a time and check the status. I would power them ON, check status for the one, after status should appear GOOD. Then power it off then power ON the next RBS and do same to be sure each one gets good status.
- FURRYe38Oct 08, 2021Guru - Experienced User
Can give this a try:
