msarrel
Feb 25, 2022Aspirant
RBS750 Firmware Update Trouble
I accidentally upgrade the firmware on my RBR750 to V4.6.5.14 before upgrading the firmware on my RBS750. Now, I'm trying to manually update the RBS750 from V4.6.3.16 to V4.6.5.14. But, I can't ...
msarrel
Well, I made some progress. I followed the instructions in this issue and connected directly to the RBS750 website via its IP address. I updated the firmware again, and then cycled the power on both the RBR750 and RBS750. Now, both router and sattelite agree that the sattelite has V4.6.5.14.
I'm still having trouble getting the sattelite to sync with the router, but I'll keep you updated on that.
- FURRYe38Feb 26, 2022Guru - Experienced User
I recommend you update to this on the RBS first, then RBR lastly:
Netgear has set up a community forum specifically for the Orbi AX products. Most of the people who watch that forum are more likely to have experience with Orbi AX (WiFi6 RBK 3,7,8 and 9 Series) products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
