mondrin
Dec 07, 2022Guide
RBS750 has purple status but is fully functional
I've got the CBR/RBS750 set. CBR has FW V4.6.5.8. RBS has FW V4.6.5.14. The RBS750 started showing a solid purple light a few days ago but is otherwise fully functional. It shows connected in the...
mondrin
Dec 07, 2022Guide
I appreciate your response but it's pretty generic and doesn't fully apply since the CBR750 is the modem and router combined. I would love to factory reset the RBS750 but don't know how. I've tried using a paper clip and pressing the reset button for 30+ seconds but that didn't do anything. I access the RBS750 by browsing to 192.168.1.250 using chrome or Edge. I found the IP using an IP scanner.
Dec 07, 2022Guru - Experienced User
The rbs will get a default address of 192.168.1.250 but it should change after first setting up and syncing with the router.
do you have it hardwired into the router? or wireless?
Try connecting it via a hardwired connection to the router and trying it. It should give you a different ip address.
Someone also pointed out the CBK750 satellites have their own firmware so make sure the firmware you're using for it is the one specific to that set.
https://www.netgear.com/support/product/cbk752.aspx#download
