jwst
Jul 26, 2023Aspirant
RBS750 intermittent light colors and backhaul connection
I have a RBR750 and RBS750 that I am trying to redeploy in AP mode. The RBR750 is working fine (wifi and ethernet ports) but I can't get the RBS750 to be stable. It is typically showing a magenta f...
- Jul 27, 2023
That would be a cause. Glad you figured it out.
Yes since the RBR has it's own firewall and would be on a different sub net.
DMZ is to help with a double NAT condition when having two routers on the same line. DMZ just allows all traffic thru the 1st router to pass thru to the 2nd router. And since the 2nd router has a firewall, this allows two routers to be on same line while functioning independently.
jwst
Firmware is 4.6.14.3
RBR750 is connected to Unify Dream Router using ethernet in AP mode. (RBR750 is working fine).
I have good cables all around (Cat 6 and 5e. Have checked all with tester.)
RBR750 and RBS750 are currently directly connected via ethernet (no switch) with about 10 feet of cable.
Jul 26, 2023Guru - Experienced User
And both have PINK front LED?
Does the RBS appear correctly in the RBRs web page under Connected Devices?
