molecules
Jan 30, 2023Aspirant
rbs750 intermittently losing internet connection to rbr750
Hi!
I have been having issues and have been working with support since October 2022. The satellite loses internet connection intermittently (ethernet and wifi). It happens anywhere from a few s...
Feb 17, 2023Guru - Experienced User
One last ditch effort I would try, manually download the RBS and RBR FW files and use a wired PC and web browser to re-load to the RBS first, then RBR lastly.
After the system processes the update, power everything OFF for 1 minute then back ON.
Factory reset the RBR using:
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
I'd bring the RBS to same room as the RBR or near the RBR that's close enough for you to factory rest the RBS and resync them. Button press the reset button on the RBS for 15 seconds then release.
Setup the RBR from scratch using the wired PC and web browser.
Set channel 1 and 40 or 11 and 48.
Set 40Mhz channel width only.
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
Enable SIP ALG under Advanced Tab/Setup/WAN Setup.
After the system is setup, save off a backup config to file for safe keeping.
Power off and deploy just one RBS at a remote location, 30 feet away from the RBR.
Check this to see if the RBS continues with the problem or not. If it does, may need to get in touch with NG support.
molecules
Feb 17, 2023Aspirant
I discovered something interesting today. I have been running long ping tests to google.com. I ran into the issue where it started saying request timed out. I then tried browsing to google.com but could not get to the page. The web browser said it was having trouble finding the web page. I opened another powershell terminal and pinged 192.168.1.1 and it also was showing connection timed out. Interestingly, I had a browser open to Twitch and that was running and did not lose connection the entire time.
- KevinLiTFeb 17, 2023NETGEAR ModeratorHello molecules,
Welcome to the NETGEAR Community!
I understand that you are having issues with network stability with your RBS750.
Please try disconnecting one of the satellites and then verify if the issue is still present on the connected satellite (Please try this step with both satellites). If it is not present then you may need to resync the second satellite to your RBR750 while the first satellite is connected to your RBR750. If the issue is still present within the individual satellites, please try reinstalling the FW for your RBS750 as recommended by FURRYe38.
Please use the link below for the firmware download file for your RBS750:
https://www.netgear.com/support/product/rbk752.aspx#download
Best,
Kevin
Community Team - moleculesFeb 27, 2023Aspirant
I have made the changes and am still getting the weird disconnects from the satellite.
Just in case others run into the same issue and need a recap:
Router RBR750
2x satellites RBS750
They were rock solid from February 2022 to October 2022. Devices connected to the satellite (ethernet and wireless) randomly lose internet. Base router and connected devices do not lose internet. What I have observed:
- Ping tests to google.com will say request timed out
- Browsing from a web browser says timeout
- Ping to 192.168.1.1 (router) will say timed out
- Interestingly, one time when this happened I was on twitch in the web browser, no other pages would load, but the twitch connection remained.
What have I attempted:
- hard reset of router and satellites
- swapping satellite positions
- upgrading firmware via the routerlogin web page as well as downloading the newer version on the netgear website.
- RMA'd router twice
- RMA'd satellite twice
- downgrading router and satellite firmware to 3.x
- Various configuration settings recommended by Netgear Community as well as Netgear support
Observations about netgear support:
It really is a roll of the dice as to the quality and helpfulness of the support techs. Some have claimed to have tech issues, after reading my case notes, and say they will call back but never do (I think they probably have metrics and are afraid of missing them). Others create a new case (again I think they have metrics) even though there is an open case.
I have used both the premium support techs (way more consistent) and the purchased gearhead support techs (not as consistent). There definitely have been a few support techs that care and have tried to help, but for the most part, you get a lot of lackluster support techs.
I am definitely disappointed with Netgear. Up until this point I have exclusively bought Netgear products and recommended them to friends and family. After dealing with Netgear Support I do not recommend them anymore. The support is a nightmare.
The Netgear Community has been wayyy more helpful than the Netgear Support (gearhead and premium). I appreciate your time!!!
These cases span from October of 2022 to the latest one January of 2023.
X
I do not have a resolution for the issues. I think I am going to bite the bullet and just run Cat6 throughout the house for the desktop computers. I might try Ubiquiti, which a lot of my coworkers recommend.
