koolbreeze7's avatar
koolbreeze7
Follower
Aug 12, 2022
RBS750 no devices connecting
Hi everyone, I have a RBS750 router with two satellites. It's a three story single family home. My issue is the router is in the basement, one satellite each in the upper two levels. No devices are ...
  • plemans's avatar
    Aug 12, 2022
    Its actually your phone that decides whether what router/satellite to connect to.
    It might have a good enough signal when it connects to either router/satellite 2 when it first connects that even when its being moved around, it doesn't need to roam.
    If the router/satellites are to close together, you can try reducing their broadcast power to see if that helps with the roaming.
    but if its working well, I probably wouldn't fiddle to much with it.
