GFT
May 28, 2022Aspirant
RBS750 no longer connects
I have an RBR750 and a pair of RBS750s that have been working flawlessly for a year and a half. The RBS750s are running firmware version V4.6.5.14. One of the RBS750s (MAC *A1) now reports as disconn...
May 30, 2022Guru - Experienced User
What FW version is on the RBS?
Do the RBS appear as connected in the RBRs web page using Safari?
Please post a screen capture of what your seeing.
- GFTMay 30, 2022Aspirant
They all show the same firmware version number.
The RBS750 shows up in the connected devices list with no IP address and a "backhaul status" of Disconnected.
- FURRYe38May 30, 2022Guru - Experienced User
What happens if you turn OFF the RBS that shows connected and take the other RBS and place it in same location as the working RBS?
I didn't try moving the non-functional RBS to the same location as the functional unit, but I did move it to the same room as the RBR, just a few feet away. No change. I also tried connecting it directly to the RBR with a 2 meter Ethernet cable. In all cases I can ping the "disconnected" RBS750 (using the IP address for the satellite that my Fing box reports as a new device each time I plug in the wired connection, or the (wireless) IP address that my RBR reported months ago when the satellite was working). And in all cases the RBR reports that it is still disconnected.
Can you access the one RBS web page at the IP address it's assigned when its ethernet connected to the back of the RBR?
