sonic80
Nov 23, 2022Aspirant
RBS750 not able to sync with RBS750
Hello all Until a week ago my setup worked without problems (RBR750 with a RBS750 satellite). In the meantime I am in the following situation: RBR750 does not see the satellite anymore. Desp...
Nov 25, 2022Guru - Experienced User
Are you sure the RBS updated to same version of FW?
What the system auto updated or do you manually update the RBS first then RBR lastly?
Power OFF the RBS, RBR and ISP Modem for 1 minute then back ON with the modem first, RBR next then RBS.
Might try a full on reset and setup from scratch on the RBS then RBR. I would bring the RBS to same room and sync and add them one at a time.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
sonic80
Nov 25, 2022Aspirant
Hello
Yes, same FW.
Manualy installed.
Did the poweroff, restart, full resets many times. Same Room.
Downgraded FW of the Satelite, testet again no success.
