joe_var
Jun 06, 2022Aspirant
RBS750 not connecting to RBR750
Hi all, First of all sorry if someone already posted this issue here but I was unable to find the exact same issue on my own. I bought a RBR750 with 2 RBS750 satellites, and managed to connec...
Jun 07, 2022Guru - Experienced User
joe_var wrote:
Hi all,
I bought a RBR750 with 2 RBS750 satellites, and managed to connect th router with the first satellite without an issue. I have been trying to connect the second one for 2-3 days lately but I am unable to connect it.
I tried:
- plugging the satelitte to power and follow the step on the orbi app but the satellite just keeps flashing white and is never detected
- doing factory reset and re-doing the steps on the orbi app, but still flashing white and not detected
- bringing the satelitte to the same room as the router... no luck
what else can I do? I am not able to send a message to Netgear on top of that...
thanks
Joe
- joe_varJun 10, 2022Aspirant
FURRYe38 wrote:What Firmware version is currently loaded?
The loaded SW is V4.6.5.14_2.0.54.
The modem is from SAGEMCOM and model is LIVEBOX 5 from Orange France.
thanks a lot in advance.
Joe
- FURRYe38Jun 10, 2022Guru - Experienced User
Does the RBS connect to the RBR if you ethernet connect it to the back of the RBR?
Does it get a IP address for the RBS seen on the RBRs web page?
Your ISP modem seems to have a built in router and wifi already. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- joe_varJun 14, 2022Aspirant
FURRYe38 wrote:Does the RBS connect to the RBR if you ethernet connect it to the back of the RBR?
Unfortunately no... is does not connect and continue flashing white!
FURRYe38 wrote:Does it get a IP address for the RBS seen on the RBRs web page?
I have another satellite (I bought a pack of RBR + 2 RBS) connected to the router wirelessly and it does have an IP address.
FURRYe38 wrote:Your ISP modem seems to have a built in router and wifi already. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI am not expert, but with my previous Orbi pack I never add an issue (only RBR + one RBS). This new one that I have today, also works fine with RBR and one RBS... I just don't get why can't I connect the second RBS and why it remains flashing white and nothing seems to make it stop.
thanks a lot for your help.
Best regards,
Joe
