joe_var
Jun 06, 2022Aspirant
RBS750 not connecting to RBR750
Hi all, First of all sorry if someone already posted this issue here but I was unable to find the exact same issue on my own. I bought a RBR750 with 2 RBS750 satellites, and managed to connec...
Jun 07, 2022Guru - Experienced User
joe_var wrote:
Hi all,
I bought a RBR750 with 2 RBS750 satellites, and managed to connect th router with the first satellite without an issue. I have been trying to connect the second one for 2-3 days lately but I am unable to connect it.
I tried:
- plugging the satelitte to power and follow the step on the orbi app but the satellite just keeps flashing white and is never detected
- doing factory reset and re-doing the steps on the orbi app, but still flashing white and not detected
- bringing the satelitte to the same room as the router... no luck
what else can I do? I am not able to send a message to Netgear on top of that...
thanks
Joe
joe_var
Jun 10, 2022Aspirant
FURRYe38 wrote:What Firmware version is currently loaded?
The loaded SW is V4.6.5.14_2.0.54.
The modem is from SAGEMCOM and model is LIVEBOX 5 from Orange France.
thanks a lot in advance.
Joe
- FURRYe38Jun 10, 2022Guru - Experienced User
Does the RBS connect to the RBR if you ethernet connect it to the back of the RBR?
Does it get a IP address for the RBS seen on the RBRs web page?
Your ISP modem seems to have a built in router and wifi already. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- joe_varJun 14, 2022Aspirant
FURRYe38 wrote:Does the RBS connect to the RBR if you ethernet connect it to the back of the RBR?
Unfortunately no... is does not connect and continue flashing white!
FURRYe38 wrote:Does it get a IP address for the RBS seen on the RBRs web page?
I have another satellite (I bought a pack of RBR + 2 RBS) connected to the router wirelessly and it does have an IP address.
FURRYe38 wrote:Your ISP modem seems to have a built in router and wifi already. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI am not expert, but with my previous Orbi pack I never add an issue (only RBR + one RBS). This new one that I have today, also works fine with RBR and one RBS... I just don't get why can't I connect the second RBS and why it remains flashing white and nothing seems to make it stop.
thanks a lot for your help.
Best regards,
Joe
- FURRYe38Jun 14, 2022Guru - Experienced User
You can try updating the one working RBS first to v.2 FW then then the RBR lastly. then see if the 2nd RBS will ethernet connect to the RBR.
