joe_var
Jun 06, 2022Aspirant
RBS750 not connecting to RBR750
Hi all, First of all sorry if someone already posted this issue here but I was unable to find the exact same issue on my own. I bought a RBR750 with 2 RBS750 satellites, and managed to connec...
joe_var
Jun 10, 2022Aspirant
FURRYe38 wrote:What Firmware version is currently loaded?
The loaded SW is V4.6.5.14_2.0.54.
The modem is from SAGEMCOM and model is LIVEBOX 5 from Orange France.
thanks a lot in advance.
Joe
Jun 10, 2022Guru - Experienced User
Does the RBS connect to the RBR if you ethernet connect it to the back of the RBR?
Does it get a IP address for the RBS seen on the RBRs web page?
Your ISP modem seems to have a built in router and wifi already. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- joe_varJun 14, 2022Aspirant
FURRYe38 wrote:Does the RBS connect to the RBR if you ethernet connect it to the back of the RBR?
Unfortunately no... is does not connect and continue flashing white!
FURRYe38 wrote:Does it get a IP address for the RBS seen on the RBRs web page?
I have another satellite (I bought a pack of RBR + 2 RBS) connected to the router wirelessly and it does have an IP address.
FURRYe38 wrote:Your ISP modem seems to have a built in router and wifi already. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI am not expert, but with my previous Orbi pack I never add an issue (only RBR + one RBS). This new one that I have today, also works fine with RBR and one RBS... I just don't get why can't I connect the second RBS and why it remains flashing white and nothing seems to make it stop.
thanks a lot for your help.
Best regards,
Joe
- FURRYe38Jun 14, 2022Guru - Experienced User
You can try updating the one working RBS first to v.2 FW then then the RBR lastly. then see if the 2nd RBS will ethernet connect to the RBR.
- joe_varJun 16, 2022Aspirant
FURRYe38 wrote:You can try updating the one working RBS first to v.2 FW then then the RBR lastly. then see if the 2nd RBS will ethernet connect to the RBR.
OK, I have done the update, weirdly I can connect my deviced to the Orbi wifi, but cannot connect to the router via the web app, nore to the android app, says it is not finding the orbi network, while connected at it...
