Abhi_V
May 23, 2024Aspirant
RBS750 not connecting to RBR750
Trying to setup new RBK753 with two satellites. managed to connect RBR750 to modem successfully during setup process I was prompted to update firmware to latest version 7.2.6.31 which I did but both ...
May 23, 2024Guru - Experienced User
Were the RBS connected during the setup process or no? If no, then the RBS didn't get updated first which is required, before the RBR does.
Can you ethernet connect the RBS to the back of the RBR and see if they get an IP address from the RBR? If they do, use this IP address to log into each RBS and update them manually to v.31:
