slosrt8
Nov 14, 2022Tutor
RBS750 not showing in attached devices on my CBR750
So yesterday I got a notification in my CBR750 that new firmware was available. I should have known better than to update it. But I did and now my RBS750 (which was working perfectly before the FW up...
- Nov 14, 2022
Be sure you update the RBS first the CBR lastly when the system has a FW update and be sure update the RBS only from the CBKs support page seen here:
https://www.netgear.com/support/product/cbk752.aspx#download
Do NOT use other FW update files from the Orbi RBK system pages for the RBS that comes with the CBR. These FW versions are NOT compatible with the CBR!!!
michaelkenward
Nov 14, 2022Guru - Experienced User
slosrt8 wrote:
I HAVE FOUND A SOLUTION. HOW DO I CLOSE THIS THREAD.
Tell people what the solution is. (And win their eternal gratitude.)
Then mark that as Accept As Solution.
