hd1106
May 12, 2022Aspirant
RBS750 not syncing with CBR750
Hello all, Recently purchased these Orbi setups and everything worked fine until firmware updates. The CBR firmware was 4.6.3.6 and the RBS firmware was 4.6.5.14. As soon as I update the CBR firm...
hd1106
May 17, 2022Aspirant
Hello,
Yes, I ended up just updating both router and satellite with the latest firmwares. The satellite shows up on the network map now as (Netgear) instead of the model number. Everything seems to be working fine. I just left it alone and it automatically updated on the application a day or 2 later. Here is a screenshot...
May 17, 2022Guru - Experienced User
What it look like on the CBRs web page under Connected Devices?
So you have v4.6.5.8 on the CBR and v4.6.5.14 on the RBS?
